2OrbiOrNot2Orbi
Jun 23, 2018Aspirant
RBW30 (Satellite) Not Issuing IP Addresses
I have the RBR40 Router and two RBW30 Satellites. One of the satellites allows devices to connect to the satellite, but kills the connection to the internet. I can be connected to the router, then wa...
DarrenM
Jun 25, 2018Sr. NETGEAR Moderator
Have you tried to enable fast roaming in the advanced wireless settings?
DarrenM
2OrbiOrNot2Orbi
Jun 25, 2018Aspirant
It was off. I've turned it on and will keep an eye out for improvements. Thanks for the suggestion.
