Ulairi
Apr 16, 2018Luminary
RBW30 Wall Plug Satellite causes disconnects with RBK50
Per background in this thread, I am continuing to get disconnects with an iPhone that are caused to RBW30 wall plug satellite. This has come back again, after firmware updates to the latest vers...
schumaku
Apr 16, 2018Guru - Experienced User
As it's not really documented - I'm not convinced it's a great idea to combine the "small" RBS40 Satellite or RBW30 Wall-plug Satellite with thier 2x2 AC 867 Mbit backhaul with the "big" 4x4 AC 1733 Mbit backhaul - if this is a) possible at all, and b) meaningful.
Only for the Orbi Outdoor RBS50Y the compatibility is documented (because it can work with some Orbi and the Orbi Pro: "Requires Orbi Router (RBR50, RBR40, RBR20 or SRR60 – sold separately)" [this part would be very clear] "or use with your existing Orbi WiFi System" [and that's more then vague again].
Some clarification by Netgear is required here.
However, in other threads we see the RBK50 Paired With Two RBW30 ...
Ulairi
schumaku wrote:As it's not really documented - I'm not convinced it's a great idea to combine the "small" RBS40 Satellite or RBW30 Wall-plug Satellite with thier 2x2 AC 867 Mbit backhaul with the "big" 4x4 AC 1733 Mbit backhaul - if this is a) possible at all, and b) meaningful.
This Wall Plug satellite is supposed to be compatible with the RBR50 router.
Per page 3 of the product data sheet for the RBW30:
"What Do I Need for Orbi to Work?
• ORBI ROUTER (RBR40 or RBR50) – SOLD SEPARATELY "
The RBK52 is the kit consisting of "1 RBR50 + 2 RBW30"
On the product packaging for the RBW30 it says:
• Orbi Router – SOLD SEPARATELY "
I suspect that they're being non-specific about which routers so that they can keep releasing new routers (e.g. RBR20)
