mashevloff
Mar 01, 2024Aspirant
Rdr50/rds50 create separate vlan for iot devices
All my devices are attached to rdr/rds50 and work well. I'd like to create vlans so the iot devices are on one network and others on another vlan. I bought a pfsense box and a netgear managed switch b...
Mar 04, 2024Guru - Experienced User
FYI, Orbi AX 7,8 and 9 series all have separate IoT Wi-Fi networks just for those IoT devices that need only 2.4ghz setup connections.
Also the Orbi AC model series of systems is EoL.
CrimpOn
I'm confused. Some specific models of Orbi ac appear on this page:
https://www.netgear.com/about/eos/
But others, such as the RBR50 do not. For example:
RBW30
RBR50
Maybe the Orbi ac units are "SOL".
- FURRYe38Mar 04, 2024Guru - Experienced User
Ya, that page needs updating.
