happyintruder
Aug 13, 2019Aspirant
2.4 Ghz issues with nest cameras and zodiac iAqualink
I too was wanting to purchase the Orbi with 1 sattelite....but after reading these post, I am very hesitant....i also have Nest front door camera, 6 ADT cameras and a ZOdiac iAquilink system.....All ...
CrimpOn
Aug 14, 2019Guru - Experienced User
Oh, heavens, YES, use the EXACT same WiFi name (SSID) and password. I have kept the same credentials through three router replacements. If you want to back, just plug in the old router.
What would prompt some to change from Velop to Orbi?
happyintruder
Aug 14, 2019Aspirant
my Velops Router continues to receive internet from my cox modem and speed test show 50-95gbs down and 9,9 up while connected to the lan cable 7” away from modem and router…..across the other 2 satellites, they keep dropping off line…..Wireless connections are around 30 down adn 9 up…….called cox and they say I have everything goo…..so I think the router is bad.
