CrimpOn
Apr 30, 2020Guru - Experienced User
2.5.1.16 Results Only
Could we please have a post that ONLY contains reports of firmware 2.5.1.16? i.e. "My Orbi is now at firmware 2.5.1.16 and I observe: No change. Everything is the same as before. What worked con...
May 04, 2020Guru - Experienced User
Do you have just 1 RBS or do you have more?
changds wrote:Correction: same as before (2.5.1.16 vs. 2.5.1.8) - the RBS50 satellite still periodically reboots itself (blue ring appears for several minutes while wi-fi is down).
steve8411
May 04, 2020Apprentice
Well on my RBS50Y, I regenerated the passkey, reconnected and the unit synced with a good connection.
5 minutes later, shows disconnected.
Once again, nice work Netgear - NOT.
- FURRYe38May 05, 2020Guru - Experienced User
I recommend you contact NG support and file a suport ticket on the RBSY. The FW needs to be updated on the RBSY to ensure it works correctly with new Orbi FW v16.
https://www.netgear.com/support/#
steve8411 wrote:Well on my RBS50Y, I regenerated the passkey, reconnected and the unit synced with a good connection.
