daDozer
Mar 27, 2020Tutor
400 Bad request after update 2.3.5.32
Why do I always run into some error when I update firmware on these devices? I went through hair ripping frustration last time with no internet connection, solving the solution with a manual update. ...
Retired_Member
Apr 08, 2020
daDozer wrote:
Why? Because I got an email from netgear saying there was a security update I needed to run.
Not clear on why they send those out. You didn't have to update.
However, the only firmware updates you NEED are those that NG pushes automatically.
You may need to revert back to your previous version.
daDozer
Apr 08, 2020Tutor
I've tried several different firmware downgrades over the past week or so. When I found one that worked, it didn't disconnect for several updates. Until my devices updated to the most recent firmware automatically. Any suggestions?
- Retired_MemberApr 08, 2020
daDozer wrote:
I've tried several different firmware downgrades over the past week or so. When I found one that worked, it didn't disconnect for several updates. Until my devices updated to the most recent firmware automatically. Any suggestions?what does this mean..."Until my devices updated to the most recent firmware automatically."
look for the version you last had that was stable for you
- daDozerApr 08, 2020TutorIt just means that the orbi system automatically updated. I did find a firmware that was stable, it ran well for a couple days without losing connection but the devices automatically updated, and I'm having the disconnecting issue again.
daDozer wrote:
It just means that the orbi system automatically updated. I did find a firmware that was stable, it ran well for a couple days without losing connection but the devices automatically updated, and I'm having the disconnecting issue again.the reason I ask is because in your OP....you stated.."when I update firmware "......
so you did nothing but wake up one day and your Orbi system was broke?
