mrdbarnes
Oct 16, 2020Aspirant
AC Power Adapter
I purchased an RBR20 Mesh router with 1 Sattelite from Costco. The specs I was looking for were not on the package but I took a chance. MOST of the equipment I purchase have power adapters that accep...
mith_it
Oct 25, 2020Luminary
I bought one of these and works great. Make sure you check the power output
mith_it
Oct 26, 2020Luminary
- mrdbarnesOct 26, 2020Aspirant
Thanks,
Are you using an RBR20 Mesh router? The voltage output on the 120V supplied unit is 1.5A while the Amozon uint you listed is 3.5A. the I have not yet measured the pin size. Being overseas, I have to use a 3rd party re-shipping agent (added fees) so returning items I cannot use is 2x extra cost. I am sad that NETGEAR has NO response to my inquiry. I see many of their devices have 110-240V adapters and was surprised to find the limitations of the adapters supplied.
Thanks for your feedback
- mith_itOct 27, 2020Luminary
No I'm using it with an RBS50. I just looked at power and polarity
