Joelovinlife
May 03, 2020Aspirant
AC2200 Orbi Router(Dos Attacks - Loss of Service)
So I'm having the popular issue of DOS attacks. I've done some research and see most Netgear Routers report these in their logs. However, I lose internet connection randomly through out the day and al...
Joelovinlife
I am thinking the same...thx for the info.
Not sure if its a Netgear thing or maybe a malfunction in the Router.
OrbiPhilip
Aug 08, 2020Luminary
Did you ever find a solution? I've been experiencing intermittent LOS for a week now. Assumed it was xfinity, but tonight I noticed a correlation between Orbi reporting a DOS attack and Nagios reporting loss of connectivity to CNN, Google, Etc.
Example:
Nagios Log excerpt:
August 08, 2020 12:00 Host Up[2020-08-08 12:10:44] HOST ALERT: one_dns;UP;SOFT;1;PING OK - Packet loss = 0%, RTA = 11.43 ms Host Up[2020-08-08 12:10:16] HOST ALERT: google_dns;UP;SOFT;1;PING OK - Packet loss = 0%, RTA = 11.92 ms Host Up[2020-08-08 12:10:15] HOST ALERT: CNN_http;UP;SOFT;1;HTTP OK: HTTP/1.1 301 Moved Permanently - 499 bytes in 0.048 second response time Host Up[2020-08-08 12:10:12] HOST ALERT: google_http;UP;SOFT;1;HTTP OK: HTTP/1.1 301 Moved Permanently - 547 bytes in 0.052 second response time Host Down[2020-08-08 12:10:09] HOST ALERT: CNN_http;DOWN;SOFT;4;CRITICAL - Socket timeout after 10 seconds Host Down[2020-08-08 12:10:06] HOST ALERT: google_http;DOWN;SOFT;3;CRITICAL - Socket timeout after 10 seconds Host Down[2020-08-08 12:09:57] HOST ALERT: google_dns;DOWN;SOFT;1;(Host check timed out after 30.01 seconds) Host Down[2020-08-08 12:09:53] HOST ALERT: CNN_http;DOWN;SOFT;3;CRITICAL - Socket timeout after 10 seconds Host Down[2020-08-08 12:09:50] HOST ALERT: google_http;DOWN;SOFT;2;CRITICAL - Socket timeout after 10 seconds Host Down[2020-08-08 12:09:40] HOST ALERT: one_dns;DOWN;SOFT;1;(Host check timed out after 30.01 seconds) Host Down[2020-08-08 12:09:37] HOST ALERT: CNN_http;DOWN;SOFT;2;CRITICAL - Socket timeout after 10 seconds Host Down[2020-08-08 12:09:34] HOST ALERT: google_http;DOWN;SOFT;1;CRITICAL - Socket timeout after 10 seconds Host Down[2020-08-08 12:09:20] HOST ALERT: CNN_http;DOWN;SOFT;1;CRITICAL - Socket timeout after 10 seconds August 08, 2020 08:00 Service Ok[2020-08-08 08:51:52] SERVICE ALERT: CNN_http;HTTP;OK;SOFT;1;HTTP OK: HTTP/1.1 301 Moved Permanently - 499 bytes in 0.046 second response time Host Up[2020-08-08 08:47:08] HOST ALERT: CNN_http;UP;SOFT;1;HTTP OK: HTTP/1.1 301 Moved Permanently - 499 bytes in 0.046 second response time Host Up[2020-08-08 08:47:05] HOST ALERT: google_http;UP;SOFT;1;HTTP OK: HTTP/1.1 301 Moved Permanently - 547 bytes in 0.038 second response time Host Down[2020-08-08 08:47:02] HOST ALERT: CNN_http;DOWN;SOFT;4;CRITICAL - Socket timeout after 10 seconds Host Up[2020-08-08 08:47:02] HOST ALERT: google_dns;UP;SOFT;1;PING OK - Packet loss = 16%, RTA = 13.37 ms Service Critical[2020-08-08 08:47:01] SERVICE ALERT: CNN_http;HTTP;CRITICAL;HARD;1;CRITICAL - Socket timeout after 10 seconds Host Down[2020-08-08 08:46:59] HOST ALERT: google_http;DOWN;SOFT;4;CRITICAL - Socket timeout after 10 seconds Host Down[2020-08-08 08:46:46] HOST ALERT: CNN_http;DOWN;SOFT;3;CRITICAL - Socket timeout after 10 seconds Host Down[2020-08-08 08:46:43] HOST ALERT: google_http;DOWN;SOFT;3;CRITICAL - Socket timeout after 10 seconds Host Down[2020-08-08 08:46:42] HOST ALERT: google_dns;DOWN;SOFT;1;(Host check timed out after 31.01 seconds) Host Down[2020-08-08 08:46:30] HOST ALERT: CNN_http;DOWN;SOFT;2;CRITICAL - Socket timeout after 10 seconds Host Down[2020-08-08 08:46:27] HOST ALERT: google_http;DOWN;SOFT;2;CRITICAL - Socket timeout after 10 seconds Host Down[2020-08-08 08:46:14] HOST ALERT: CNN_http;DOWN;SOFT;1;CRITICAL - Socket timeout after 10 seconds Host Down[2020-08-08 08:46:11] HOST ALERT: google_http;DOWN;SOFT;1;CRITICAL - Socket timeout after 10 seconds
Orbi Log excerpt:
[DoS Attack: SYN/ACK Scan] from source: 94.130.44.37, port 30120, Saturday, August 08, 2020 12:38:34 [DoS Attack: ACK Scan] from source: 208.73.181.96, port 443, Saturday, August 08, 2020 12:33:07 [DoS Attack: ACK Scan] from source: 208.73.181.200, port 443, Saturday, August 08, 2020 12:33:03 [DoS Attack: ACK Scan] from source: 208.73.181.96, port 443, Saturday, August 08, 2020 12:28:07 [DoS Attack: ACK Scan] from source: 208.73.181.200, port 443, Saturday, August 08, 2020 12:28:03 [DoS Attack: ACK Scan] from source: 208.73.181.96, port 443, Saturday, August 08, 2020 12:23:07 [DoS Attack: ACK Scan] from source: 208.73.181.200, port 443, Saturday, August 08, 2020 12:23:03 [DoS Attack: ACK Scan] from source: 208.73.181.96, port 443, Saturday, August 08, 2020 12:23:03 [DoS Attack: ACK Scan] from source: 162.250.6.136, port 5938, Saturday, August 08, 2020 12:10:13
[DoS Attack: TCP/UDP Chargen] from source: 83.97.20.35, port 35004, Saturday, August 08, 2020 11:31:07 [DoS Attack: SYN/ACK Scan] from source: 94.130.44.37, port 30120, Saturday, August 08, 2020 10:35:01 [DoS Attack: TCP/UDP Echo] from source: 141.212.123.205, port 36044, Saturday, August 08, 2020 10:12:53 [DoS Attack: ACK Scan] from source: 45.61.142.175, port 10668, Saturday, August 08, 2020 09:31:16 [DoS Attack: ACK Scan] from source: 208.73.181.200, port 443, Saturday, August 08, 2020 09:09:57 [DoS Attack: ACK Scan] from source: 208.73.181.96, port 443, Saturday, August 08, 2020 09:09:52 [DoS Attack: ARP Attack] from source: 192.168.1.55, Saturday, August 08, 2020 09:05:59 [DoS Attack: ACK Scan] from source: 208.73.181.200, port 443, Saturday, August 08, 2020 09:04:57 [DoS Attack: ACK Scan] from source: 208.73.181.96, port 443, Saturday, August 08, 2020 09:04:52 [DoS Attack: ACK Scan] from source: 208.73.181.200, port 443, Saturday, August 08, 2020 08:59:57 [DoS Attack: ACK Scan] from source: 208.73.181.96, port 443, Saturday, August 08, 2020 08:59:52 [DoS Attack: RST Scan] from source: 18.218.187.50, port 6500, Saturday, August 08, 2020 08:47:11 [DoS Attack: SYN/ACK Scan] from source: 87.236.16.53, port 80, Saturday, August 08, 2020 08:34:23 [DoS Attack: RST Scan] from source: 13.224.85.92, port 443, Saturday, August 08, 2020 08:16:22
- MstrbigAug 09, 2020Master
The Orbi has a habit of finding an overwhelming amout of DDOS attacks. Even though you may want to see these reports, there may be many coming from Google, Amazon, Microsoft, Apple, etc., adding overheads to the processing of the Orbi. You can turn off DDOS attack logging, or put up with it. Turning off logging may help with stability issues. Since there are so many entries to the log, the processor gets taxed and slows down because of the extra work.
- schumakuAug 09, 2020Guru - Experienced User
Mstrbig wrote:The Orbi has a habit of finding an overwhelming amout of DDOS attacks.
Correct. The
OrbiNetgear router have a habit of finding an overwhelming amount of DDOS attacks.Most occurrences are false positives, caused by _real_ connection loss on the WAN/Internet side, or caused from clients going to sleep or roaming awy with open TCP sessions.
- OrbiPhilipAug 09, 2020LuminaryHow would an LOS create the illusion of a DDOS?
