beguna1
Apr 17, 2022Tutor
Adding 2nd satellite brings down network intermittently
I've had my Orbi and 2 satellites for years with no problems when they operated in Access Point mode. Last September, Google Fiber replaced their modem/router with a modem and I changed the Orbit to...
beguna1
Apr 18, 2022Tutor
The bottom line is that with two satellites connected directly to the Orbi router by WIRE (and even by WiFi as I found during an accidental test by WIFI when I left a wire disconnected), when both satellites are turned on, when one is showing good the other is showing config sync or disconnected. If I turn off the first one the second one shows good. If I turn off the second one, the first one shows good. The Orbi router does not work with two satellites at the same time. And I've tried it with 2 different Orbi routers and 3 different satellites. I don't think the size of the house is relevant but it is about 5000 square feet and each Orbi is on a different floor and we are talking mostly wired testing. And yes I tried factory resets of the routers and satellites and all are running same latest firmware that Netgear posted.
I have to wonder, how many people own two Orbi satellites and don't know that one isn't working because they never look at the app or the Orbi web site.
I never had this problem when using the Orbi router as an Access point instead of as a router. (Google Fiber replaced their modem/routers with modems last September.) I also was using an Orbi router as an access point for a while instead of a using a second satellite. Didn't have a problem then either. Problem is using two satellites. Doesn't work.
beguna1
Apr 21, 2022Tutor
A few days ago I replaced my Netgear Orbi with a combination of Google Wi-Fi and Google Nest Wi-Fi. Problems have disappeared. Network does not go down. Two wired Google Nest points and one wired Google Wi-Fi points working well connected by wire to Google Wi-Fi router. But here is the interesting thing. Just received a long post of complaints on my phone that people are having similar problems with the Google stuff as I had with the Orbi stuff. So far I've had no problems. But I have to wonder if ISP's have changed something recently that is messing with some mesh systems in general.
