beguna1
Apr 17, 2022Tutor
Adding 2nd satellite brings down network intermittently
I've had my Orbi and 2 satellites for years with no problems when they operated in Access Point mode. Last September, Google Fiber replaced their modem/router with a modem and I changed the Orbit to...
FreedomII
Oct 19, 2022Aspirant
Yes. I have resorted to the factory reset and clean rebuild. I have spent some time (way too much time). Testing out the setting of:
- Daisy Chain Topology: Disabled (exception: if you have 3 or more satellites)
beguna1
Oct 19, 2022Tutor
I should add that when I had the problem, I not only replaced the satellites but I replaced the router. All was a waste of time and effort. Look at the router's built in website and see what's happening. Disconnect one satellite and then the other. You will see that things are stable with only one connected. Connect two and they take turns disconnecting. That was what convinced me to give up.
- FreedomIIOct 19, 2022Aspirant
What is interesting is that it is not a connectivity issue from the RBR to the RBS. While the WiFi issue occurs, the backhaul connection is "GOOD" on the built-in website connected device status page. Unfortunately, I do not see anything in the RBR logs when the issue us occurring.
- beguna1Oct 19, 2022Tutor
How long did you watch it for? Did the path to the internet remain stable during this time? Mine failed quickly at the end but I was probably getting intermittent failures earlier that I was not aware of. You need to check connectivity when there is a failure, I would think.
