dwayneycl
Sep 06, 2020Aspirant
Airplay & Orbi Mesh Network
Device Orbi RBR40*1 / Orbi RBS40*1 / Orbi RBS50*1 My hompod(or any airplay device) is connected to RBS50, but my phone is connected to RBS40 showing that my phone cant not airplay to hompod, is the...
Mstrbig
Sep 06, 2020Master
dwayneycl wrote:Device
My hompod(or any airplay device) is connected to RBS50, but my phone is connected to RBS40 showing that my phone cant not airplay to hompod, is there any that I can do?
Can you describe how you have your Satellites set up? If your phone is on the same subnet as your hompod, you should not be having this issues. Your satellites will all be on the same subnet as the router. So anything connected wired or wirelessly, will be pulling its IP address from the DHCP. Ping the IP address of the hompod and post your results.
I would check your network settings and WIFI settings on the phone and compare them to the hompod.
mith_it
Sep 06, 2020Luminary
I use AirPlay no problem. Sounds like something is wrong in the satellites setup
