zcastagna84
Feb 02, 2021Tutor
Amazon prime video thinks VPN is active
Hi, within the last couple of days, any device on WiFi that tries to open prime video is greeted with a message saying a VPN is active. This is not the case. Chrome casts, iOS devices, laptops, etc al...
Feb 02, 2021Guru - Experienced User
Do you have Armore or Circle enabled?
zcastagna84
Feb 02, 2021Tutor
No, I haven’t used either of those services
- FURRYe38Feb 02, 2021Guru - Experienced User
Just checking...
- zcastagna84Feb 02, 2021TutorI saw some Reddit posts where people had the same or similar issue and they worked with the ISP to get their IP address changed
Yes, I would try that as well. Seems like Amazon is fixed on your current WAN IP which for some reason maybe causing problems. Worth asking them about.
