comanchepilot
Apr 30, 2020Tutor
Any problems switching from 192.168.1.1 to 192.168.0.1
Hi Guys - my orbi arrives when UPS gets it here today and I've been reading up - I have two printers that have static IP's - one of them is a scanner and the other is a color laser that is Apple Prin...
- Apr 30, 2020
Set a new default IP addrss pool of 192.168.1.100 to .200, then you can set static IP addressed devices on either side of this pool.
Static IP addressed devices need to be out side of the default IP address pool while IP reservations are with in the pool.
I have 3 printers, cameras and 3 NAS set up with static IPs on the devices. I'm also using 192.168.0.1.
Apr 30, 2020Guru - Experienced User
I see my mistake, typo:
"Set a new default IP addrss pool of 192.168.1.100 to .200, then you can set static IP addressed devices on either side of this pool."
I meant to put 192.168.0.100 to .200. My bad. :smileyembarrassed:
comanchepilot
Apr 30, 2020Tutor
I saw that but figured it was a typo - thanks again - make sense
