ReneK
Nov 17, 2019Aspirant
Re-assigning mac address keeps disrupting wired speaker
Goodmorning, At irregular times my KEF LS50 Wirelsess speakers lose connection. They are wired to the RBR50-sattelite. Now I noticed that the loss of connection coincides with the log beneath: 1...
CrimpOn
Nov 17, 2019Guru - Experienced User
ReneK wrote:At irregular times my KEF LS50 Wirelsess speakers lose connection. They are wired to the RBR50-sattelite.
Can you please clarify this: The spec I found on the product web site indicate 2.4G/5G WiFi. They do not show an ethernet jack.
- ReneKNov 17, 2019AspirantYes indeed, it has a network-port and I connected my speakers to it. Works fine, if not interrupted...
- CrimpOnNov 17, 2019Guru - Experienced UserYou are absolutely correct. I found a picture of the back side of the main speaker that clearly shows the RJ45 network jack.
Does the speaker drop out when connected with WiFi?- ReneKNov 17, 2019Aspirant
I dont know. Found a lot of related problems with DHCP re-assignments but no solutions. I think I will contact the helpdesk directly to sort this out. Dont want to start old discussions again on this forum. But if I get the solution, I will share it immediately. Thanks for thinking with me!
