ReneK
Nov 17, 2019Aspirant
Re-assigning mac address keeps disrupting wired speaker
Goodmorning, At irregular times my KEF LS50 Wirelsess speakers lose connection. They are wired to the RBR50-sattelite. Now I noticed that the loss of connection coincides with the log beneath: 1...
CrimpOn
Nov 17, 2019Guru - Experienced User
ReneK wrote:At irregular times my KEF LS50 Wirelsess speakers lose connection. They are wired to the RBR50-sattelite.
Can you please clarify this: The spec I found on the product web site indicate 2.4G/5G WiFi. They do not show an ethernet jack.
ReneK
Yes indeed, it has a network-port and I connected my speakers to it. Works fine, if not interrupted...
- CrimpOnNov 17, 2019Guru - Experienced UserYou are absolutely correct. I found a picture of the back side of the main speaker that clearly shows the RJ45 network jack.
Does the speaker drop out when connected with WiFi?- ReneKNov 17, 2019Aspirant
I dont know. Found a lot of related problems with DHCP re-assignments but no solutions. I think I will contact the helpdesk directly to sort this out. Dont want to start old discussions again on this forum. But if I get the solution, I will share it immediately. Thanks for thinking with me!
- FURRYe38Nov 17, 2019Guru - Experienced User
Have you set up a IP address reservation for the RBS and your speaker device ON the RBR? No static IPs on the speaker device. Should use auto IP address assignment here.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
ReneK wrote:I dont know. Found a lot of related problems with DHCP re-assignments but no solutions. I think I will contact the helpdesk directly to sort this out. Dont want to start old discussions again on this forum. But if I get the solution, I will share it immediately. Thanks for thinking with me!
