Foxeslink
Oct 13, 2019Aspirant
Best option for my house
Hey, so I have a large home and I want internet in certain areas. My house is Full Wired so I can have the best internet. The problem is I dont know what to Buy. I need 3 aps or Orbi system. Two of th...
CrimpOn
Oct 14, 2019Guru - Experienced User
Foxeslink wrote:
I forgot something that might be important.
So I know I can use the lan ports of the main orbi router to connect the sattelites. But can one be connected from the ISP?
ISP - main orbi router - sattelite 1
ISP - switch - sattelite 2
That is generally not a good idea. If the Orbi is in router mode, it absolutely will not work. If the Orbi is in Access Point (AP) mode, I am not 100% certain that it will fail, but would not attempt it.
I would recommend ISP - main Orbi router - switch - satellite 1 and satellite 2.
Foxeslink
Oct 14, 2019Aspirant
So, that will not work.
Let's try another way,
I drew the frame, I want to know if it's possible to do this:
https://i.imgur.com/M309ZB7.jpg
- CrimpOnOct 14, 2019Guru - Experienced User
That will work as long as the WiFi satellite is close enough to get a strong signal.
Most people recommend to put the satellite about 10 meters (30 feet) to start with and adjust from there.
Too close is not recommended because the WiFi signals will interfere.
But, WHERE is that switch now?
- FoxeslinkOct 14, 2019Aspirant
Yes, wifi sattelite will be 10-15 meters away
Sorry, now it's the final frame : https://i.imgur.com/EzXcb5F.jpg
I don't need the second switch, because satellite 3 works as wifi
If this truly works, I can now buy the system!
- ekhalilOct 14, 2019Master
Yes, this should work. Go for it!
Good luck
- FoxeslinkOct 15, 2019AspirantOrdered!
As about configuration, I should configure them normally, like it was wireless? and then I just need to wire the router orbi to the sat 1 and I think it should be done. The sat 2 should automatically detects the router - CrimpOnOct 15, 2019Guru - Experienced User
I am probably too old and cautious. I like to have them all in the same room so that I can see what the lights are doing and fuss with them without having to run back and forth through the house. If a satellite will not do a WiFi sync in the same room, then it certainly will not do one farther away in the house. Likewise, I would connect up an ethernet cable and verify that wired backhaul is working before moving the satellite to its permanent location.
The units are also likely to want a firmware update. Who knows when they left the factory and how long they have been sitting in one warehouse or another. Get that all done before the final placement.
- FoxeslinkOct 18, 2019Aspirant
So I Got my RBK configured them, and it's all working. But.. my wifi speed in 5ghz should be 200mbps and I just can do it like 90mbps.
What am I'm missing ?
- ekhalilOct 19, 2019Master
- Which device do you use to test the wifi speed?
- Do you get the same speed when attached to the Router as when attached to the Satellite?
- What speed do you get in wired devices?
- Which 5GHz channel do you have in Orbi? Any neighbors using the same channel? Please make wifi scan and check. Change the channel if needed.
- Please enable MU-MIMO in the advanced wireless settings.
- FoxeslinkOct 19, 2019Aspirant
ekhalil Sudenly, I did some speedtests and now the speed is what it should be. So strange! In a moment, everything did right.
I have 1 SSID, and the devices choose automatically if it should connect to the 5ghz or 2.4 ghz. That's good!anyway, let me ask you, what settings should I enable or disable to get the best performance of this system ?
thank you
Daisy-Chain feature should be enable or disable in my case ?
Foxeslink wrote:ekhalil Sudenly, I did some speedtests and now the speed is what it should be. So strange! In a moment, everything did right.......
There miight have been radio interference from neighbour router that caused the issue earlier.
It's recommended that you make a wifi scan and select the most suitable radio channels for the 2.4 and 5 GHz bands
I think it's always good to have MU-MIMO enabled.
For Daisy Chain it's up to you, if the wireless Satellite is closer to the other Satellite than to the Router then you may choose to allow daisy chain connection for that Satellite, otherwise it's better to disable Daisy Chain.
I setted daisy chain disabled because the Wifi satellite is closer to the router than the other satellite.
In the attached devices, the type connection of the Wireless Satellite is 2.4ghz but in the past was 5ghz. The satellite is close to the router, I'm confident that does not mean its a bad connection. I can anyway get the 200mbps of speed. But I wonder why it's sometimes in 2.4 in type connection
thank you for your help. You trully deserve some beers
In fact, not a good idea disable the chain tipology. The wireless satellite type connection is keeping "poor". I still have the maximum wifi speed. I enabled the chain again, and the connection is always "good".
Strange things I'll never understand :D
Foxeslink wrote:In fact, not a good idea disable the chain tipology. The wireless satellite type connection is keeping "poor". I still have the maximum wifi speed. I enabled the chain again, and the connection is always "good".
I don't think it's Daisy Chain that causes the Satellite to connect to the Router over 2.4 or 5 GHz band. I think if you just wait some time the backhaul will change automatically to the 5 GHz band.
- FoxeslinkOct 19, 2019AspirantYes, you are right. It changes to the 5ghz.
My only concern is that disabling the chain the wifi quality is set to be poor. Its so strange because the satellite is exactly in the same place, and with the chain active the quality is good. Guess it won’t be bad the chained remains activate. Anyway, you could clarify me about this. I think there was a time that with that setting off the quality remain good for 1 time. The wired satellite is always good btw
