Foxeslink
Oct 13, 2019Aspirant
Best option for my house
Hey, so I have a large home and I want internet in certain areas. My house is Full Wired so I can have the best internet. The problem is I dont know what to Buy. I need 3 aps or Orbi system. Two of th...
Foxeslink
Oct 19, 2019Aspirant
ekhalil Sudenly, I did some speedtests and now the speed is what it should be. So strange! In a moment, everything did right.
I have 1 SSID, and the devices choose automatically if it should connect to the 5ghz or 2.4 ghz. That's good!
anyway, let me ask you, what settings should I enable or disable to get the best performance of this system ?
thank you
Foxeslink
Daisy-Chain feature should be enable or disable in my case ?
