Foxeslink
Oct 13, 2019Aspirant
Best option for my house
Hey, so I have a large home and I want internet in certain areas. My house is Full Wired so I can have the best internet. The problem is I dont know what to Buy. I need 3 aps or Orbi system. Two of th...
ekhalil
Oct 19, 2019Master
Foxeslink wrote:In fact, not a good idea disable the chain tipology. The wireless satellite type connection is keeping "poor". I still have the maximum wifi speed. I enabled the chain again, and the connection is always "good".
I don't think it's Daisy Chain that causes the Satellite to connect to the Router over 2.4 or 5 GHz band. I think if you just wait some time the backhaul will change automatically to the 5 GHz band.
Foxeslink
Oct 19, 2019Aspirant
Yes, you are right. It changes to the 5ghz.
My only concern is that disabling the chain the wifi quality is set to be poor. Its so strange because the satellite is exactly in the same place, and with the chain active the quality is good. Guess it won’t be bad the chained remains activate. Anyway, you could clarify me about this. I think there was a time that with that setting off the quality remain good for 1 time. The wired satellite is always good btw
