DorkiOrbiFW
Jun 28, 2019Apprentice
Best Performance for Ring Devices (Orbi Config. Settings)
Hello Orbi Community, I am sure a lot of you use a Ring Video Doorbell, Ring Spotlight Cam, Ring Floodlight Cam, etc. on your Orbi network. I have seen a good majority of Orbi users that have Rin...
- Oct 19, 2019
Hello everyone,
There has been a lot that has happened since the last time I wrote.... so allow me to give a BIG explanation and a PERMANENT fix to ALL THIS CRAP!
- I truly thought that I did have defective spotlight cams, but turns out after a week and a half of the installation of all the replacements issued for my old units, I was back at square one with inconsistent launching of live view feeds.
- END RESULT: ISSUE PERSISTED; NOT DEFECTIVE CAMERAS
- I began to realize that I had an ongoing Orbi problem that was causing satellites to have syncing issues and dropping connection on devices connected to them at random despite my satellites all showing "GOOD" backhaul status. I kept waiting for a good and stable firmware to come out from Netgear to correct any bugs (if any) to correct the issues I was experiencing and firmware 2.3.5.30 came out. However, the issue still persisted and caused my Orbi to still operate incorrectly. I became desperate and was seriously about to RMA my entire system, but I also know that a factory reset after a major firmware update is sometimes needed to clear old and incompatible configurations from previous firmwares that cause the Orbi to misbehave.
- END RESULT: ISSUE PERSISTED; NOT BAD FIRMWARE
- Factory reset my entire system (Orbi router and satellites) and setup from scratch.
- So.... WTF was the solution you ask?
- My solution came from an article I stumbled upon that listed to run telnet commands I had yet to try to correct the issues I was experiencing. SW_'s tip and/or trick RESOLVED ALL issues I was experiencing. His trick assists in "fixing the Orbi WiFi network becoming unstable, random rebooting, and WiFi connectivity problems that occur after applying new Firmware Update(s)." However, I did modify his trick slightly. Please proceed to item number (5) for the proper solution to fix your ongoing issues with your Rings Spotlight Cams, other Ring devices, or hell, even any other regular device experiencing issues on your Orbi network.
- SOLUTION
- Go to the debug page of the satellite (EX: Unit_IP_Address/debug.htm) and click the checkbox near Telnet to ENABLE Telnet (do process on router and ALL satellites).
- Telnet into each satellite along with the router and type the following codes EXACTLY as shown and in the EXACT order (The codes may be executed on ALL Orbi routers and satellites, with the exception of the RBW30 satellite. If you have RBW30, please see alternate form.):
- config default
- config commit
- reboot
- Alternate Telnet Form - Applies to RBW30 Satellites Only
- reset
- reboot
- When you complete the above commands via telnet on your satellites, they should begin rebooting and pulse white.
- Factory reset the Orbi and setup from scratch. DO NOT utilize a backup file of an old configuration as you will defeat the purpose of this process and the issues willl then reoccur.
- Connect to the factory default SSID name that is now being broadcasted by your Orbi router and then go through the Orbi setup wizard. To get things up and running faster, I highly suggest hitting "skip" when it prompts you to setup satellites as you can do that later and it is best to wait to sync your satellites after you change Orbi's default advanced settings in order to have your Ring devices perform well.
- Configuring your Orbi for Ring Best Performance (this has been updated since last time I wrote in):
- BASIC -> Wireless, choose 40 for 5Ghz band (Offers the best signal and usually permits Orbi to have the best backhaul. Netgear recommends this channel for 5Ghz) and utilize whatever 2.4Ghz channel works best in your environment and your Ring devices. In my environment, I run 2.4Ghz band on Channel 3, and 5Ghz on Channel 40. Hit Apply when completed!
- ADVANCED -> Setup -> WAN Setup, under the section titled NAT filtering, select the OPEN radio button. Then, click on the checkbox to Disable SIP ALG. Hit Apply when completed!
- ADVANCED -> Setup -> LAN Setup, give ALL Ring devices address reservations (MUST). I also recommend giving all satellites an address reservation as well (though the satellite address reservation is optional and not required). Hit Apply when completed!
- ADVANCED -> Advanced Setup -> Wireless Settings, please ensure your configuration matches the configuration below. If you don't have your configuration the same as mine here, you will experience issues with your Ring devices. Hit Apply when completed!
- DISABLE WMM on BOTH 2.4Ghz and 5Ghz
- DISABLE MU-MIMO
- ENABLE Implicit Beamforming
- ENABLE Fast Roaming
- Add all your satellites back to your Orbi router to enable synchronization.
- Most Ring devices will reconnect on their own and be stable in about 2 days after the intensive troubleshooting on your Orbi network. However, if they do not, just go on outside and simply reconnect them to the Orbi network and you'll be just fine.
- ENJOY! I have had no issues to date! :smileyvery-happy:
*If you have any questions on how to access telnet, DM me and I'll gladly assist you or you can find how to do it via other forums listed within the community.
rosey99
Jan 02, 2020Tutor
I was wondering if it worked with eero and figured yes. That answers that question. Go figure since Amazon owns EERO and Ring. Maybe a purposeful bug in Ring?? Would not shock me in the least. Amazon is known for these types of antics when dealing with a major competitor. Don't expect it to ever get fixed is my guess. The only way will be if we figure out why WMM doesn't cripple speed for some or if Netgear figures a way around the issue without hurting speed. For now I'm going to use my Asus as an access point and see if that fixes the situation.
DorkiOrbiFW
Jan 02, 2020Apprentice
These issues occur on ANY mesh system (there is also a bunch of forums for Ubiquiti Amplifi users with Ring). It will happen on EERO as well. The Ring devices have a hard time understanding mesh networks (though I haven't had much problems and when I did, I solved it with these settings). While it may be a forced bug, I'm leaning towards it not being one. A high level Ring advisor told me this (and as I come from a background in IT, this is true), "With Ring always updating firmware along with Netgear), it does make it hard sometimes to pinpoint who the culprit really is". However, I have told Ring repeatedly it is on there end, but is anything done about it? NOPE! They just sit on their ass and give the generic answers of restart your router or replacement options. Though, when I reached a high level advisor, we tried rolling back firmware, and my issue at one point still remained. It was not until I changed my setttings around that things were fixed. Orbi or Ring? Could be both, but I'd lean towards Ring more. At one point in time, settings didn't matter on my Orbi and ALL of my Ring devices worked flawlessly. It wasn't until my actual Ring devices updated their firmware (come to think of it around the time Amazon acquired them) that it forced me to find a solution. I have no idea why some have problems with WMM with this, however.
On another note, I do want to mention that the Ring devices will sometimes reconnect automatically back to the network using a farther away satellite. It is recommended to reconnect them manually after a reboot of the network. Additionally, I have had success sometimes performing a hard reset on the Ring devices for them to stay up permanently, however I'm not going to guarantee this will fix things.
I will keep researching and let you know if I find something. I haven't had any issues with speed and connectivity for 2.5 months straight.
Best,
- rosey99Jan 02, 2020Tutor
Thanks OrbiMechanic. Yep I too have some real world IT experience dealing with Amazon...they aren't fixing it unless they have to and it helps them financially. I too think it's an issue on their side since as you said, it is happening on more than just Orbi. Also, if indeed the issue still happens on EERO as you think it might and their support is telling people that this only works reliably in EERO that is incredibly irresponsible and maybe more by Amazon. Who knows though if that CSR was supposed to say that. Also, who knows, maybe they do know it works reliably on EERO since they own both and you would think if they did test on a mesh system, that would have to be the one.
Anyway, thanks for the help and hopefully we can at least find out why WMM cripples speed for many. If we can figure that out (obviously there has to be a setting or real reason) then we can get around this problem and any possible shenanigans Amazon may or may not be up to.
- TechbobJan 02, 2020AspirantYou hit the nail on the head
I have enough satellites for good coverage of our home, and specifically my issue is what you said. Ring devices randomly disconnect from the closest satellite and reconnect to the furthest one.
I have not yet bit the bullet to reconfigure with the recommendations.
Ps for what it is worth ring devices do the same thing if you are unfortunate enough to have tried to use more than one Chime Pro for a “Chime Pro Network “
I wish Ring could learn from Sonos, how the Sonosnet works, as well as how Zwave works.- FraterpJan 02, 2020Aspirant
I found a hidden QOS menu in the router: http://routerlogin.net/QOS_main.htm
Any suggestions for what we might want to try?
