alokeprasad
Mar 22, 2025Mentor
Best way to factory reset a disconnected RBR and RBS 50's
Hi all, I have powered off and disconnected my RBR and 2 RBS 53's. These were replaced by another (newer) mesh system. The new network is functional. Unfortunately, before switching over to th...
Mar 22, 2025Guru - Experienced User
Power them on and push and hold reset for 30 seconds. that'll clear them out.
alokeprasad
Mar 22, 2025Mentor
How do I verify that they are clean after I do that? Re-attach them to my new (eero) network?
In the past, when I was using them and tried that, they would accept the password and have the same wifi passwords when they were done powering on. Didn't behave like they were fresh from the factory units.
Aloke
