StuMcBill's avatar
Jan 04, 2019
Can I route all traffic through a VPN?
Hi,   Can I setup the Orbi to route all my internet traffic through a VPN?  I've read that the VPN service section under advanced setup doesn't work like that?  If not, is there anyway I can do t...
  • st_shaw's avatar
    Jan 04, 2019
    Orbi's VPN is for remote access to your LAN.  To do what you describe, you would need to run Orbi in Access Point mode behind a third party router that supports VPN as a client.
