jonseff
May 10, 2022Tutor
Can no longer connect using orbilogin.com or entering 192.168.1.1
Having the exact same problem. Can no longer connect using orbilogin.com or entering 192.168.1.1 (tried three different Mac browsers and both http and https, as well as iPhone and iPad), or using the...
May 11, 2022Guru - Experienced User
What model Orbi do you have?
You need to factory reset the RBR and setup from scratch using a wired PC and web browser:
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
jonseff
May 11, 2022Tutor
Thanks. I have an RBR750 with three satellites. Was hoping to fix this without nuking my whole system. Will have to fix when I have a bunch of free time and the kids out of the house so they won't complain about the Wi-Fi đ.
This is my second Orbi setup (the first simply stopped putting out a wireless signal after several years) and probably my last.
