struan99
Sep 05, 2021Tutor
Can Orbi cause problems for Virgin Media SuperHub 3?
Problem: I am using a Virgin Media Superhub 3 in modem mode, connected to a Netgear Orbi RBR50 router. Periodically (sometimes every 5 minutes or so, sometimes once an hour), the Superhub loses its i...
- Sep 06, 2021
I wasn't able to open that spreadsheet (I don't have Excel, and tried in Google Spreadsheets without success). Also, the Superhub 3 lost its connection again this morning while running in router mode and connected to the Orbi. However, I had another (a third!) visit from Virgin Media today. The engineer switched my hub, giving me a Superhub 4 to replace the Superhub 3. When the engineer tried to put that Superhub 4 in modem mode, with the Orbi connected, nothing worked. When he tried putting it in router mode, and disabling wifi via the Superhub 4's control panel, everything did work. I've had a stable connection for the intervening 3 hours or so. I'll cross my fingers that it all continues working, though I'm still baffled as to what went wrong originally, or *why* this approach would work. Thanks for helping me with all this!
struan99
Sep 06, 2021Tutor
ROLgear
Jul 21, 2022Aspirant
hi struan99 I am in a similar position, before I go chasing Virgin I was wondering if you had the problems repeat after the visit. Thanks
- struan99Jul 21, 2022Tutor
Hi there,
I didn't have that same problem after the visit. I have had another, unrelated problem with my Virgin Media service, but that one was resolved. (The next problem that I had was with packet loss - which turned out to be a fault in the cable in the street. That only took a further few months of calls, call-outs, and general annoyance to fix. I really hate the service I get from Virgin Media.)
