NeoVN's avatar
NeoVN
Can Orbi RBS50 Satellite connect to RBS50 Satellite???
I bought 1 set RBK53S and 1 RBS50. That mean I have 1x RBR50 and 3xRBS50. Can anyone help me how to connect like this wifi map??? RBS50 <-> RBR50 <-> RBS50 <-> RBS50 Becauae all my RBS50 connect to...
  • FURRYe38's avatar
    Sep 06, 2019
    Yes, enable Daisy Chain. Under Advanced Tab/Advanced Settings/Wireless Settings.
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
