Reproman
Sep 26, 2022Aspirant
Cannot Put Outdoor Satellite Into Extender Mode
I have tried several times to get my RBS50Y into extender mode to use with my new Orbi WiFi 6 network by following the published instructions. Tried multiple resets and power cycling, but I am unabl...
Sep 27, 2022Guru - Experienced User
So to get Extender mode on the RBSY, first the Extender Mode firmware has to be loaded on the RBSY while it's connected to a Orbi compatible system. Once the RBSY has the extender mode FW loaded on it, then it could be connected to a Orbi AX system. It won't fully integrate like the RBS do however will run like a NG extender and provide wifi coverage. I see that Extender mode FW is only available for the RBS50Y v2. v1 only has support or Orbi home systems and Orbi Pro systems.
Reproman
Sep 27, 2022Aspirant
Thanks for your reply. Yes, I had read that the Extender Mode firmware limitation existed for the RBS50Y version 1, but unfortunately not until I had already switched over to the Orbi 6 and couldn’t get the extender mode up and running on the RBS50Y. I was hoping that someone might have come up with a workaround to allow for RBS50Y extender use in this situation. But it seems not to be the case. More planned obsolescence.
- CrimpOnSep 27, 2022Guru - Experienced User
Yes, if what you have is an RBS50Yv1, then you are well and truly screwed.
- It cannot work as an AX satellite because the RBS50Y WiFi radio chips are not compatible with the AX radio chips. and
- It cannot work as a regular WiFi Extender because Netgear did not make the v2 firmware backward compatible with the v1 model.
It's too tall and too light for a doorstop.
