JDSiph
Aug 24, 2020Tutor
CBR40 with external modem (yes, but with an RBS20 also?)
Hello all, I read in another thread I can use my CBR40 with an external modem by disabling DHCP, etc.. I look forward to trying this in order to get more longevity from my Netgear Orbi investmen...
- Aug 27, 2020
Thats a modem only, Theres no router built in to that modem. You would need a router in between that modem and the CBR40 if you were to try to connect the CBR40 in AP mode.
Aug 25, 2020Guru - Experienced User
What is the IP address string your main host router your using that you want to connect the CBR too?
Ya don't use bridge mode on the CBR, this disables wifi and router portion of the CBR making it a modem only unit.
What you have to do is set a a new IP address from 192.168.0.1 to a new IP address, Depending on what your using on your host router will help here first off. I did try this once with mine as I set a 192.168.0.40 on the CBR. Disabled the DHCP server on the CBR and applied the change. My main host routers IP address pool is 192.168.0.100 to .150 so the .40 used on the CBR is out side of the host routers default IP address pool which is fine and is preferred. I then used the .40 address to connect to the CBR40s web page from here. This will never change as well.
JDSiph
Aug 26, 2020Tutor
Thanks FURRYe38. I think it relates to my Spectrum modem not doing DHCP correctly. Only willing to assing one IP address? Hard to say for sure but I've spent way too much time trying to salvage this. Sadly, I abandoned it and purchased a new WiFi router. It's a waste of a good CBR40 but in the end, I needed the network to work.
Thanks again....
- FURRYe38Aug 26, 2020Guru - Experienced User
What is the mfr and model# of the ISP modem your using?
