JDSiph
Aug 24, 2020Tutor
CBR40 with external modem (yes, but with an RBS20 also?)
Hello all, I read in another thread I can use my CBR40 with an external modem by disabling DHCP, etc.. I look forward to trying this in order to get more longevity from my Netgear Orbi investmen...
- Aug 27, 2020
Thats a modem only, Theres no router built in to that modem. You would need a router in between that modem and the CBR40 if you were to try to connect the CBR40 in AP mode.
Aug 26, 2020Guru - Experienced User
What is the mfr and model# of the ISP modem your using?
