Hrannarm
Feb 11, 2020Initiate
Change connection on Iphone to 2.4GHz in Orby app
Hi. I am trying to connect my security cameras to my iPhone and it says I need to have my phone on 2.4GHz, how can i switch to 2.4GHz in my mobile orby app??
CrimpOn
Feb 12, 2020Guru - Experienced User
It would help if you specify the model of camera. In my (limited) experience, a lot of cameras have their "app" display a smart code and the camera is pointed at the smart code to login.
Also, just a "technicality", but the immediate goal is to connect the camera to WiFi, correct? Later, the iPhone can connect to the camera, either from at home or from elsewhere?
Hrannarm
Feb 12, 2020Initiate
They have there own app, denali I think it is and they say that I can only add the camera on 2.4Ghz
- FURRYe38Feb 12, 2020Guru - Experienced User
Once you disable the 5Ghz SSID broadcast, save and apply. Do a "Forget this Network" on your phone or pad. Disable the wifi radio on the phone or pad, then re-enable it, then reconnect to the Orbi WiFi. The phone or pad should be now connected to the 2.4Ghz frequency.
- CrimpOnFeb 12, 2020Guru - Experienced User
Hrannarm wrote:
They have there own app, denali I think it is and they say that I can only add the camera on 2.4GhzThe box that now has "Freyjubrunnur1..." What was there before?
So, what happened when you just put in the Orbi WiFi name and password and click on "Done"?
