Gebla
Sep 05, 2019Apprentice
Connected but no internet
In the past i made a split into a ssid on 2.4 and a ssid to 5 ghz because i had a problem with several devices on 5 ghz. On 5 ghz devices show connected to wifi but they get no or very slow internet. ...
Sep 11, 2019Guru - Experienced User
So far with AP mode you are getting connected and internet access now right?
What is the mfr and model# of the wired switch your using behind the modem?
Gebla
Sep 11, 2019Apprentice
Yews, only after moving to AP mode and to a complete wireless backhaul setting I get internet. Although I still get no data for some seconds, when that happens I can see that I am switching between RBS. This happens a few times during longer internet browsing
For me Orbi does not work with wired backhaul, you cannnot connect other wired devices to it and it can not work as router (only as AP). Considering these limitations I think Orbi is way to expensive.
- FURRYe38Sep 11, 2019Guru - Experienced User
That would be a device handling issue, not the Orbi. The device maybe choosing which source to connect to based on distance, signal and noise.
You may have a bad system thats possible. Ethernet back haul works. How my system is connected. Others have this working as well. Hard to tell if this is a HW failure here or configuration...
Overall, you might ask for an RMA or get a replacement from the place you bought this from to see if the problems stop. If not, i would conclude that this is a environment and configuration issue there.
- GeblaSep 11, 2019Apprentice
The problem is that Netgear refuses warranty as I did some Telnet on the device in the past (to change to 2.4 and 5GHZ). According to Netgear I changed the product. and they refuse to accept that factory reset would restore it into original version.
