annejanz
Dec 09, 2022Follower
Connected to 4G/LTE network, but no internet
Hi all, I have been using the Netgear Orbi (LBR20) for a couple of months now with no problems, but now it lost internet connection. It has full reception (all bars are visible) and gets an IP addr...
KevinLiT
Dec 15, 2022NETGEAR Moderator
Hello annejanz,
I understand that you are unable to connect to the internet with your LBR20. Please factory reset your LBR20 then connect to the internet and verify the connection status.
Please let me know if you are still experiencing this issue after your factory reset!
Best,
Kevin
Community Team
Zosia
Jan 15, 2023Aspirant
Hi I have similar problem. It is connected with wifi on orbi but from tomorrow no internet - sim card is OK I checked it several times the provider of internet also. Speed test shows 1mbps/ I rebooted Orbi also... Screen added. What to do more?
- ZosiaJan 15, 2023AspirantScreen
