Vrtualized
Jul 25, 2020Aspirant
Constant issues with Orbi/Neato and Orbi VPN with Zoom and Skype
Ever since I hooked up my Orbi I have had constant issues. It has been the most unstable router set that I have ever used. But that isn't the worst part. I literally cannot use video with Zoom or Skyp...
Vrtualized
Jul 26, 2020Aspirant
FURRYe38 I believe there are about 4 other forums with the same suggestions from you and none of them solve the issue. I think it is time that engineers at Netgear come in and realize this is a huge problem and needs to be fixed. Please someone from Netgear see all the forums with VPN issues with Zoom/Skype etc. This needs to be fixed asap. I think I am going to switch back to my old network and back to Linksys and Asus.
DarkNet
Jul 27, 2020Apprentice
I don’t have a Neato Robot but both my wife and I are working from home in separate home ‘offices’ and we both VPN to different entities at the same time, have webex and Zoom meetings, and run other services as well without issue. I will say however that I’m only using my ORBI’s (RBR20 and RBS20) as WAPs. I have a pfSense box that is my router. I know these problems are frustrating. Did you say you were using your ORBI in router mode but also have an ATT router? I would try putting the ORBI in AP mode and NOT router mode.
