madhatter's avatar
madhatter
Apprentice
Sep 21, 2021
CONVERT RBR40 TO RBS40
I followed the instructions posted on reddit and it bricked my RBR40.  I'm guessing I didn't start out with the right firmware version before starting the process.  The reddit posts don't mention wha...
  • CrimpOn's avatar
    Sep 21, 2021
    The only conversion that I recall is turning an RBR50 into an RBS50.  Are you certain that the hack you employed is intended for an RBR40?
