paulkskim1
Nov 20, 2019Follower
Re: Cybersecurity & Tips for Protecting Your Home Network
Hi I have RBR50 worked fine for two years, but now it takes only Network band of 2.4GHz not 5.0GHz for Windows 10 pro PCs Microsoft labtop and Studio desktop PC, while my iPhone X works fine with 45...
CrimpOn
Nov 25, 2019Guru - Experienced User
The Orbi WiFi system normally provides both 2.4G and 5G WiFi channels. It is up to each device to select which connection works best.
Do you use the Orbi web interface or the Orbi "app" to monitor how devices are connected?
