paulkskim1
Nov 20, 2019Follower
Re: Cybersecurity & Tips for Protecting Your Home Network
Hi I have RBR50 worked fine for two years, but now it takes only Network band of 2.4GHz not 5.0GHz for Windows 10 pro PCs Microsoft labtop and Studio desktop PC, while my iPhone X works fine with 45...
Nov 26, 2019Guru - Experienced User
Make sure your Windows PC wifi drivers are up to date as well.
Wire connect your desktop PCs if possible.
What is the Mfr and model of the wifi adapter cards in these PCs?
paulkskim1 wrote:Hi I have RBR50 worked fine for two years, but now it takes only Network band of 2.4GHz not 5.0GHz for Windows 10 pro PCs Microsoft labtop and Studio desktop PC, while my iPhone X works fine with 450Mbps OK. I get only 54Mbps max and mostly only 25Mbps. Why is that? My Driver version is 15.68.9127.58. Do I have to buy to new router? I tried many times with reset Router to see if improves, but it doesn't correct it.
