Retired_Member
Dec 05, 2017Defect: OrbiOS 2.1.1.12 Attached Devices Widget & Page
In 2.1.12, the Attached Devices widget on the intitial page and the actual Attached Devices page do not populate even though devices and satellites are connected. Factory reset was performed mult...
- Retired_MemberDec 08, 2017
OP here:
I purchased an Eero yesterday (3 unit 2nd gen and 1 beacon) and received it around 6 PM. It was set up and has now run 16 hours without a single disconnect among 62 continually connected devices, or disconnects from another 30 devices that connect periodically as measured by a Fingbox, not anecdotal observation.
Other than having to enter about 30 port forwarding rules via an app versus a web interface, the setup was brainless and provides great feedback on node placement signal strength!
My RBK50 system with a router and 2 sats is packed in its boxes and on Craigslist. So glad to finally have stable wifi thanks to Eero!!
jmschnur923
Dec 08, 2017Luminary
My satellites show from the sat login show no attached devices. However the router says there are some.
woolyninja
Dec 08, 2017Aspirant
On v2.1.1.12 None of the Attached Devices are showing they are connected to the Satellite. At first it showed one or two but now everything says Orbi Router. Add to that the fact that every once in a while my internet now slows to a crawl and I'm quite disappointed. I really wish my Orbi wasn't automatically upgraded (to v2.0.0.74) as it was working great on the version it shipped with. Now I'm forced to return this and continue my search for a router / mesh system that'll just work.
