DarthNetwork
Jan 02, 2019Aspirant
Determining if Orbi modem/router is necessary with system?
As I am about to purchase a 2-3 Orbi system. How do I determine if I should keep the router/modem I have and plug Orbi into it or eliminate all other products and just use Orbi products? Sorry for ...
michaelkenward
Jan 03, 2019Guru - Experienced User
DarthNetwork wrote:
....or eliminate all other products and just use Orbi products?
It is most unlikely that you will be able to ditch the modem, unless you have something like a fibre-optic link into your home.
Tell us what the existing modem is, the make and model number, and it should be easy to advise you.
It can be as simple as plugging the Orbi into the modem, or it may take a small tweak to disable some of its features. Rest assured that it does not take a PhD in network engineering to set this up, so you should be OK.
