maaky4
Dec 11, 2018Aspirant
Difference between RBK22 and RBK40
Hi,
I'm looking to buy my first mesh system and I'm stuck for choice. Upon checking specifications for the RBK22 and RBK40, I could only find difference in the gigabit port availabilty. Any other p...
michaelkenward
Dec 11, 2018Guru - Experienced User
maaky4
Not much actually.
I've found the RBK22 for $180 and the RBK40 for $230.
It makes sense paying more if the latter is superior in terms of performance. Looks like the RBK22 is a newer model.
I'm surprised that Netgear Support couldn't provide me a precise answer for this issue.
- FURRYe38Dec 11, 2018Guru - Experienced User
RBK22:
Technical Specifications • Orbi AC2200 Router & AC2200 Satellite (866+866+400Mbps)† • Simultaneous Tri-band WiFi - Radio 1: IEEE® 802.11b/g/n 2.4GHz– 256QAM support
- Radio 2: IEEE® 802.11a/n/ac 5GHz– 256QAM support - Radio 3: IEEE® 802.11a/n/ac 5GHz– 256QAM support • Tx/Rx: 2x2 (2.4GHz) + 2x2 (5GHz) + 2x2 (5GHz) dedicated backhaul • IEEER 802.11a/b/g/n/ac • MU-MIMO capable for simultaneous data streaming • Implicit & Explicit Beamforming for 2.4GHz & 5GHz bands • WiFi Security: WPA/PSK2 • Processor – Router - Powerful Quad-Core 710MHz processor • Memory – Router - 256MB Flash and 512MB RAM • Antenna - Four (4) high performance internal antennas each • Ports – Orbi Router - Two (2) 10/100/1000Mbps Gigabit Ethernet ports - One (1) WAN & one (1) LAN • Ports – Orbi Satellite - Two (2) 10/100/1000Mbps Gigabit Ethernet LAN ports • Power On/Off switch • Push Button WPS and SYNC support • Voice Control - Amazon Alexa™ - The Google© Assistant • Circle® with Disney – Smart Parental Controls to manage content and time online for all your devices. Learn more at netgear.com/circle
RBK40:
Technical Specifications • Orbi AC2200 Router & AC2200 Satellite (866+866+400Mbps)† • Simultaneous Tri-band WiFi - Radio 1: IEEE® 802.11b/g/n 2.4GHz– 256QAM support - Radio 2: IEEE® 802.11a/n/ac 5GHz– 256QAM support - Radio 3: IEEE® 802.11a/n/ac 5GHz– 256QAM support • Dedicated Backhaul Technology • Four (4) high-performance antennas with highpower amplifiers • Implicit/Explicit Beamforming for 2.4 & 5GHz bands (866+866+400Mbps)† • MU-MIMO capable for simultaneous data streaming on multiple devices • Four (4) 10/100/1000Mbps Gigabit Ethernet ports - Orbi Router (RBR40): 1 WAN & 3 LAN - Orbi Satellite (RBS40): 4 LAN • Security - WPA/WPA2-PSK support - Guest WiFi Network is easy to setup separate & secure Internet access for guests
The RBK40 series data sheets don't mention Memory or CPU, however the RBK44 does:
Processor - Router & Satellites - Powerful quad core 710MHz processor each • Memory - Router - 4GB flash and 512MB RAM
Not sure if this is applicable to the RBK40 series or not. I believe it is as all the RBK4# series use the RBR40 router.
Mostly the main differences is the LAN ports in back between the 20 and 40 series. Wifi is the same.
