ryanjohn04
Oct 08, 2017Guide
Disable Guest 5Ghz
Is there a way to disable the Guest Network 5Ghz band?
aaz
Oct 08, 2017Virtuoso
No, the Orbi does not give you that level of control (yet) nor do you likely need to do that. You may 'want' to but I've yet to hear a case where somone 'needs' to.
ryanjohn04
Oct 11, 2017Guide
Thank you. Just trying to find a tricky way to get certain cams on 2.4ghz only. It’s currently connecting under 5ghz and signal is weak.
