capGrundy
Mar 18, 2021Aspirant
DNS problems
How do you have a static IP, but dynamic DNS? When static IP is selected, you cannot change the DNS option. I just started having problems where my DNS would fail until I re-appliled the curre...
- Mar 18, 2021
capGrundy wrote:I'm going to see how C.i works out with the restarts. A similar fix helped me with a proxy hang on my server.
If they persist, I appreciate the suggestion. Since I was unwilling to pay for product support beyond the short warranty period, I'm not sure they would be willing to help me.
Good luck. This issue coupled with faulty firmware has finally gotten the NG moderators here involved. Hopefully things will settle down for you and others soon.
:smileyhappy:
capGrundy
Just happened again, not even a few hours later, so feels worse.
Blanca_O
Mar 22, 2021NETGEAR Employee Retired
Hi, All,
Engineering has determined that the issue is caused by the Traffic Meter. The quick workaround is to disable the traffic meter.
To disable traffic meter:
Access orbilogin.com > go to ADVANCED Tab > Advanced Setup > Traffic Meter and uncheck Traffic Meter
Engineers are working on a firmware fix to be released.
Blanca
Community Team
