JohnsonMcShill
Jun 03, 2018Follower
Do I have to own a Disney circle to connect the parental controls to my orbi router?
TomMac
Jun 03, 2018Guru
Some routers from Netgear have it built in...( no external device needed ) ;
Partnering with NETGEAR, we've made it possible for you to use Circle on your router without the need for any additional hardware! The following NETGEAR routers currently have Circle embedded within, and need no additional equipment.
✓    READY TO GO!
⚠︎   SOON TO BE SUPPORTED
✓  Nighthawk R6700 (v1) Smart WiFi Router (AC1750)
✓  Nighthawk R7000P/R6900P Smart WiFi Router (AC2300)
✓  Nighthawk R7000/R6900 Smart WiFi Router (AC1900)
✓  Nighthawk R7900 Smart WiFi Router (AC3000)
✓  Nighthawk R8000 Smart WiFi Router (AC3200)
✓  Orbi Desktop (RB50), Mini (RB40), and Micro (RB20)
⚠︎ Others coming soon!
looks like it is on the Orbi..see https://support.meetcircle.com/hc/en-us/articles/115001380892
- JeremyinsfJun 05, 2018Apprentice
Yeah if you have one of those Orbi's it's built in, but you have to ge the app from Google Play or Apple App Store. And that will cost you $5 per month. But no extra hardware needed.
