wayne-'s avatar
wayne-
does anybody know if my netgear wn3000rp from telstra is compatible with orbi ac3000 thanks
  • peteytesting's avatar
    Jun 19, 2017
    lol only an aussie would fill out the question in the title :)
    well it will work but will compromise the orbi performance as it would be connecting to client 5 gig rather than the backhaul 5 gig
    reality if you get the orbi you should be able to dump the netgear wn3000rp
    cheer mate
    pete
