Cynomus
Oct 06, 2024Guide
Re: ERROR: NET::ERR_CERT_AUTHORITY_INVALID
I have the Orbi RBR50 and am experiencing the same, when I switch to my T-Mobile Home (redundant/backup) WiFi network, I can connect again immediately, switch back to Orbi and I can't get to the webs...
CrimpOn
Oct 06, 2024Guru - Experienced User
Cynomus wrote:
I have the Orbi RBR50 and am experiencing the same, when I switch to my T-Mobile Home (redundant/backup) WiFi network, I can connect again immediately, switch back to Orbi and I can't get to the websites again.
It is probably clear to you what "experiencing the same" means. It would be helpful if you could be specific about which websites return this invalid certificate error.
