Squeaky369
Oct 06, 2017Guide
Error while logging in - "You are currently logged in from another device."
Error while logging in - "You are currently logged in from another device." Hello everyone. I've searched around for some answers to this, but nothing solid has come up. Firmware Version 2.0....
st_shaw
Oct 06, 2017Master
Squeaky369 wrote:
My modem was replaced by my ISP and my static public IP block changed and I had to login to change it. Yes, I pay for static IPV4 addresses, not local private statics, PUBLIC STATICS.
I have AT&T Fiber, there is not another router in the picture because I have public statics.
Might be something related to your ISP setup. Although I also have multiple static IPs, that's not on my Orbi network, and it's not a common setup. I don't recall seeing anything that shows Orbi supports it.
How exactly did you setup Orbi to handle your multiple static IPs?
Squeaky369
Oct 06, 2017Guide
The Orbi only has one assigned to it, and when using a static, the modem passes all packets through, bypassig the onboard firewall.
Its not an ISP setup issue, it happens when I have the router unplugged from the internet and isolated from all devices with my quarantine laptop.
None of my previous models of routers did this, this is an issue with the Orbi. There are other posts on here talking about it, with no resolution. I’d open a ticket with Netgear, but the site is not working to submit tickets.
- shirkaanMar 29, 2018Tutor
Cant login after firmware update! you are logg imn fom other device
