garyslaben
Jan 11, 2018Follower
Ethernet Backhaul
I originally set up the system with wireless backhaul. Just now reconfigured as wired. Router status still shows satellites connected as 5G. Do I need to reset the satellites or perform some other...
Chillyb
Feb 12, 2018Aspirant
hey there - i am having same exact issues you had. did your solution work long term?
vseera
Feb 12, 2018Guide
Hi,
Yes it does seem to be working fine. I think the problem may have been some sort of incompatibility with the other switch on the network. However, after disabling almost everything on it, it seems to be stable enough.
Enough people have situations like mine and yours to say that the firmware is far from complete and bug free, but with a little bit of luck you should be able to get it working too.
Let us know how it goes for you!
