johnbday
Dec 25, 2017Tutor
Ethernet for Orbi satellites in separate buildings
New house and outbuilding construction. ISP cable modem will be in maiin house; Cat 6A cable will run from switch in house to two outbuildings 100+ feet from router (assume beyond WiFi range). No ins...
cue003
Dec 26, 2017Apprentice
With the latest firmware you can connect the satellites to the main Orbi router via Ethernet directly to the router or through a switch as you mentioned. There is an article on the support site for Ethernet backhaul connection options.
