Djzgfx
Dec 28, 2017Tutor
Facebook and Instagram Intermittent Loading
Hello, I’m having the exact same problem on my mobile devices as this post that got zero comments https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Problems-with-Facebook-and-Instagram/td-p/4971...
Nov 14, 2018Guru - Experienced User
What is the IP address the Orbi is getting from the ISP? Anything 192, 172 or 10? Or just ##.##.###.###
What are the DNS settings set for? Automatic? You can try entering in 1.1.1.1 and 9.9.9.9 or any Google DNS 8.8.8.8 and see if this helps.
You'll need to save settings if you make changes, fully reboot the Orbi router then fully reboot your mobile devices after the Orbi is back to ready.
Has the Orbi been powered down then back on after the FW update?
