Skrymir
Nov 10, 2016Guide
Firmware 1.3.0.26
The release notes included the zips are just install instructions. Anyone have real release notes for .26?
PhoenixV
Nov 12, 2016Apprentice
Well it looks like I spoke too soon. In the version 1.3.0.12 the option to turn on display of the satellite was found in the debug screen. This option was turned on when I did the update to the current version. After the update, the advance screen showing connections to the router and to the satellite continue to be displayed. However I was forced to do a reset of the entire system due to another situation. After the reset of the system and the subsequent normal set up a routine, the display of the wireless connections to the router and to the satellite are now gone, and have been replaced by one consolidated display. The option to enable the advanced view is no longer available in the debug screen. Does anyone know how to get it back?
dsc_dewain
Nov 12, 2016Guide
This is how you can get to the satelite status page: http://192.168.1.4/status.htm just be sure the ip address is of the satelite( you can try .2,.3,.4 etc
If you get there, it will prompt you for the admin password.
- peteytestingNov 12, 2016Hero
its not a matter of trying , just go to the orbi web page and it will show you the ip address of the sat / sats
- PhoenixVNov 12, 2016Apprentice
I guess I'm not being clear. What I am trying to access used to be found accessed through the hidden debug menu in order to toggle the advanced display on and off. That option no longer exists. Is there any other way to enable that advanced display?
at this stage no , but by all means make it a suggestion and hopefully if enough ppl complain or suggest they may hopefully put it back
i believe this has been done so the connected devices list is standard across both the gui and the app
