steve8411
Oct 03, 2018Apprentice
Firmware 2.2.1.210 released as of 10/3/18
New firmware is available via the GUI ....
Let's hope for success.
Oct 04, 2018Guru - Experienced User
Thank you Sir.
Christian_R wrote:
The files for download for all Orbi's should be posted soon
~Christian
jblack68
Oct 04, 2018Apprentice
I have factory reset everything and started again, the Router GUI is completly wrong, showing devices connected to Router instead of Satellite, 2.4ghz instead of 5ghz. it's a mess.
- FURRYe38Oct 04, 2018Guru - Experienced User
Happening in different browsers?
Besure to clear the browser cache before entering into the routers web page...
- deestoOct 04, 2018Guide
I also have some devices plugged in via ethernet showing up as hooked to the router on its GUI, instead of correctly being reported as wired onto the satellite.
- RedBatman89Oct 04, 2018Guide
So is anyone else getting 5ghz connection as unkown even if your do a manual firmware update with a factory reset?
Possile this may have been intended as a more simple way to show connected devices on the router. Maybe NG support can provide some behavior information.
- jblack68Oct 04, 2018ApprenticeAnother bug:
It’s enabled the guest network without my knowledge while the GUI says it’s off. Had to enable it and disable it to make sure it’s off.
Very buggy firmware.
Can you log into the Satellites UI and see whats connected at the satellite?
- jblack68Oct 04, 2018ApprenticeThe Satielle GUI works fine and shows the correct devices and correct radio they are connected to. The Router GUI is currently broken :(.
- Ryan1919Oct 04, 2018TutorMy speeds have dropped to 40mbps on the first day after I did a reboot. Using the old firmware it took 5 days or so for my speeds to drop. My old $50 router was better than this. I can’t believe this cost over 300 and doesn’t hardly work. Very disappointing. Everything was working except for the status reporting until I just tested my speeds and got 40mbps.
