steve8411
Oct 03, 2018Apprentice
Firmware 2.2.1.210 released as of 10/3/18
New firmware is available via the GUI ....
Let's hope for success.
Oct 04, 2018Guru - Experienced User
Possile this may have been intended as a more simple way to show connected devices on the router. Maybe NG support can provide some behavior information.
deesto wrote:
jblack68 wrote:
I have factory reset everything and started again, the Router GUI is completly wrong, showing devices connected to Router instead of Satellite, 2.4ghz instead of 5ghz. it's a mess.
I also have some devices plugged in via ethernet showing up as hooked to the router on its GUI, instead of correctly being reported as wired onto the satellite.
jblack68
Oct 04, 2018Apprentice
Another bug:
It’s enabled the guest network without my knowledge while the GUI says it’s off. Had to enable it and disable it to make sure it’s off.
Very buggy firmware.
- FURRYe38Oct 04, 2018Guru - Experienced User
Thank for letting us know. Did you just update FW and continue or factory reset the router and set up from scratch?
What browser are you using?
jblack68 wrote:
Another bug:
Very buggy firmware. - jblack68Oct 04, 2018ApprenticeUpdated and factory reset it. Used safari and chrome. Another bug is that if you set devices names like Adam’s iPad. The ‘ gets glitched on the Orbi iOS app. Adam#39,s iPad. This did not happen on previous firmware.
