steve8411
Oct 03, 2018Apprentice
Firmware 2.2.1.210 released as of 10/3/18
New firmware is available via the GUI ....
Let's hope for success.
Oct 04, 2018Guru - Experienced User
Can you log into the Satellites UI and see whats connected at the satellite?
jblack68 wrote:
I have factory reset everything and started again, the Router GUI is completly wrong, showing devices connected to Router instead of Satellite, 2.4ghz instead of 5ghz. it's a mess.
jblack68
Oct 04, 2018Apprentice
The Satielle GUI works fine and shows the correct devices and correct radio they are connected to. The Router GUI is currently broken :(.
- Ryan1919Oct 04, 2018TutorMy speeds have dropped to 40mbps on the first day after I did a reboot. Using the old firmware it took 5 days or so for my speeds to drop. My old $50 router was better than this. I can’t believe this cost over 300 and doesn’t hardly work. Very disappointing. Everything was working except for the status reporting until I just tested my speeds and got 40mbps.
- deestoOct 04, 2018GuideSome weird stuff happening here with the app too. App says my first satellite is in magenta, whereas web browser says it’s good and well connected (and speeds checked to verify it is so). Please see attched pictures.
- deestoOct 04, 2018Guide2nd photo
- deestoOct 04, 2018Guide3rd photo
